Sebuls
January 13, 2024, 4:51pm
1
ftp details menu say
ftp hostname ftpupload.net
but I cannot connect my site in filezilla with this info
ftp host name is ftp.freecluster.eu
https://cpanel.infinityfree.com/panel/indexpl.php
right bottom
More account setting click
Then I see
FTP host name ftp.freecluster.eu
Both should work. Have you verified you’re using the correct details?
The following article mentions some common problems you may encounter, and what steps you can try to resolve them:
Being able to access your hosting account over FTP is very important to manage your website files. However, there are reason why you may have trouble connecting to the FTP service. This article explains a few things you can try to fix your FTP connection.
Login to your control panel
After your account has been created, or reactivated after a suspension, you may need to login to the hosting control panel once to enable FTP access to your account.
You can login to the control panel by logging in…
