Website: platecore.rf.gd
Error: Error! FTP authentication failed.
I am trying to login to filemanager.ai and I fill in the correct credentials but it still does not work. I have already tried changing my password.
Make sure you are using the FTP credentials in the client area. Your main account password is different from the FTP one.
Thanks.
I used this:
Those should work correctly; can you share the full error logs in FileZilla?
Thanks.
I already mentioned I am using filemanager.ai and not Filezilla. The only thing I get is the following:
Can you please try using the FileZilla client as it will give us more detailed logs and is less prone to having random errors?
Thanks.
Now I get this:
That seams like some sort of server error. Hopefully Admin will be able to tell you more.
Thanks
I am now deleting my hosting account and recreating it.
This helps.
