What’s FTP? Why it does not work?
FTP stands for File Transfer Protocol and is a system used to exchange files with a remote server. It’s the protocol you can use to upload and download stuff from your hosting account here.
As for FTP not working, you’ll need to be a bit more specific before we can help you. For example:
- Which FTP software do you use?
- Which details do you use (hostname, username, port, directory)?
- Do you get an error message? If so, what does it say?
For the second day, I can not connect via FileZilla. Before that he came easily.
Error code:
530 Login authentication fayled
Fatal error: Can not connect to the server
OK, that answers two out of three questions and indicates it’s a login problem. Are you using the correct username and password? Have you tried to reset the account password?
Username and password are correct. But I do not try to reset the password. Now I try and write what happened
