FTP not work
I will not share it so that I don’t reach the hits limit
Screenshot 2024-10-25 at 08.47.30
None.
Did you already try this?
Please double check the password you’re using. Also, please try logging into the control panel first.
If that doesn’t work, please reset your hosting account password and then login to the control panel to enable FTP access.
It worked, I logged into the control panel and it connected with no errors.
