FTP error - Socket is not ready for use?
Hello,
I am connected to my control panel by FTP using the EditPlus client. It is very difficult to establish the connection, infact rarely, most of the time I get the error - “Socket is not ready for us”
It’s difficult to work with such connections. I am facing similar connection issue with FileZilla as well.
Is there solution/suggestion for the same?
@ananda said:
Hello,
Can you give the screenshot of the error you see?
I added an image URL from imgur. Kindly confirm if you can see it.
