Ftp do not connect
https://juanca.infinityfree.me/?i=1
since october de 3th i can not connect with ftp server ftpupload.net. always get the message time out after 20 secs.}
if i go to an online ftpclient can connet to ftp but with filezilla cannot.
any idea. i need to upgrade my site and download a little database
Estado: Resolviendo la dirección de ftpupload.net
Estado: Conectando a 185.27.134.11:21…
Error: La conexión superó el tiempo de espera después de 20 segundos de inactividad
Error: No se pudo conectar al servidor
Estado: Esperando para reintentar…
Your log shows the right IP, 185.27.134.11, so DNS isn’t the problem. The connection to port 21 just never gets an answer. Your online FTP client works, so the server is up, which points at something between your computer and the server.
I found an article on FTP connection problems. It says some routers apply an FTP ALG (a feature that intercepts FTP connections) that can break them, or block them entirely. It also says some networks and ISPs restrict FTP, and that a VPN gets around that.
Here is the article:
Can you try FileZilla from a different network, such as your phone’s hotspot, or through a VPN? If it connects there, the block is on your home network or router. If it still times out, post the full debug log from FileZilla. This guide explains how to get it:
Lemni got it right for the most part.
If I had to guess, I’d say that this is a network block on your end, from a security filter from your network administrator or ISP, or from a virus scanner. Connecting via a VPN or through your phone’s mobile data could help to bypass such network restrictions.
