“name”: “gamegam”,
“host”: “gamegam-kartrush.wuaze.com”,
“port”: 22,
“type”: “ftp”,
“username”: “if0_38495290”,
“password”: “xxxxx”,
“path”: “/”,
“autosave”: true,
“confirm”: true
] For the password, I used it for Account Details, but it doesn’t connect to ftp.
I want to connect to the Visual Studio Code and use it.
Basically, we provide it, but it’s inconvenient.
this should help
But in short your host should be ftpupload.net, ftp.epizy.com or 185.27.134.11
I don’t understand
You are using the wrong port as well
I can’t get through
What is the client password even if I change it to port 21?
the article above provides more information.
But the FTP host for infinity free is any of ftpupload.net, ftp.epizy.com or 185.27.134.11 not your websites address.
and the ftp details are in your dashboard (select the account, then ftp details)
I’ve used VSCode’s FTP with Infinity Free, and as long as you enter the correct details it works pretty well.
you might find this post useful too
If you got it from the Account Details page, you already have the right password. The reason you can’t connect is because you’re trying to connect to the wrong host and the wrong port.
After all, even with the right key, you can’t get in if you’re at the wrong door.
