MySQL Password : (Same as your current vistaPanel Password)
I have no idea what a vistapanel password is. How do i know this ?
Open the control panel, select your hosting account, then select MySQL from the sidebar. Your password will be disaplyed in on-screen.
Thank you that worked. Another question. In zilla, im following the instructions on how to view files with ftp . i created a new site and i pressed connect it wont connect for me.
it shows this:
| Status: | Resolving address of ftpupload.net |
| Status: | Connecting to 185.27.134.11:21… |
| Error: | Connection timed out after 20 seconds of inactivity |
| Error: | Could not connect to server |
| Status: | Waiting to retry… |
Try replacing ftpupload.net with ftp.epizy.com. You may have to bypass a security certificate warning.
Nope, same error. Do i have to upload the script files via file manager before i do this?
No, you should not have to, but can try it if you would like.
Here is some more information:
Not working - tried everything
It says to ask forums and give full debug logs. I tried resetting password and everything
In the logs, you can see that the FTP hostnames resolves to the correct IP address (which means trying another FTP hostname won’t work) and that FileZilla is unable to set up any connection to the FTP server, which means it’s not related to your account specifically because FileZilla isn’t even able to begin the login process.
Last time we saw issues like this it was caused by a virus scanner, firewall or other “security” product blocking access to our FTP server. It could also be that FTP access is disabled on your network entirely.
Please try disabling any security software on your own computer and connect over a VPN. That should circumvent anything trying to block the FTP connection on your end.
