FTP Connection fail
My first time trying to upload my files - using FileZilla - all connects OK until dialog says PASS… then I get an Error 530 Unable to Connect - I am copy/pasting my password from my account area, I’ve also tried manually entering it but same result - any suggestions
Further to above Actual dialog on FileZilla says 530 login Authentication Fail Critical Error Could not connect to server
Please provide ftp logs
Thanks, now set to “verbose” here is the login text after connection established
Response: 331 User######### OK. Password required
Trace: CFtpLogonOpData::ParseResponse() in state 6
Trace: CControlSocket::SendNextCommand()
Trace: CFtpLogonOpData::Send() in state 6
Command: PASS ***********
Trace: CFtpControlSocket::OnReceive()
Response: 530 Login authentication failed
Trace: CFtpControlSocket::ResetOperation(1094)
Trace: CControlSocket::ResetOperation(1094)
Trace: CFtpLogonOpData::Reset(1094) in state 6
Error: Critical error: Could not connect to server
By my reading of this (and I am NOT a 16 year old whizkid (I’m actually 80+ and only middling IT savvy) it would seem that the password is not being recognised, Am I not using the right password ? -= I’ve tried the password as per my account details, I’ve also tried my infinityfree login password, Is there another one somewhere that I’ve missed?
Please use the password provided from the client area
Thanks but that is the one I’m trying to use copy/pasted from client area tried again, same result, same dialog I’ve used FileZilla for many years at my previous hosting service with no troubles. can I change my ftp password? perhaps starting from scratch again will work, the password thats not working was assigned automatically
I think ive found where to change my ftp password, I’ll give it a try and see if it works
Changed password, then changed it in FileZilla Site Manager - then tried to connect again, Same result Same dialog
After changing password in the client area, you need to wait 10-15 minutes for the new password to be synchronised
If the problem is still present, then please:
  • provide the Website URL
  • as well as hosting/FTP acc username
  • Does the file manager from the client area (monstaFTP) successfully connect to FTP?
So that we can check if everything is working with your account (if home dir exists, IP on which work is currently being carried out, etc.).
Are you using Port 21 with FTP?
Have you tried messing with the encryption settings. Try ftp with no encryption. It works for me.
That is generally a bad idea. Our ftp server has TLS for a reason and everyone should make use of it. FTPS makes it harder for a man-in-the-middle to intercept data when compared to regular, plain FTP. Unless it is just impossible to use TLS for whatever reason (e.g, the client doesn’t support it, but I don’t know of any like that) then you should always opt to use the TLS version (for HTTP and FTP).
wackyblackie, I recently was using TLS and had no choice in the matter. It was obligatory and I could not connect otherwise.
Now, If I enable encryption It will not connect. It only works with the encryption disabled… Don’t ask me why.
My preference is to use encryption.
It turned out to be a firewall issue on my end. My policy for the FTP site was too restrictive.
My It knowledge is only middling and some of your suggestions etc dont mean a lot to me. I’ve tried using the numbers as hostname, also ftp.epizy.com but still get exactly same results
full FileZilla debug text is
Trace: CRealControlSocket::DoClose(66)
Trace: CControlSocket::DoClose(66)
Trace: CFtpControlSocket::ResetOperation(66)
Trace: CControlSocket::ResetOperation(66)
Trace: CFileZillaEnginePrivate::ResetOperation(66)
Trace: CFileZillaEnginePrivate::ResetOperation(0)
Trace: CFtpLogonOpData::Send() in state 0
Status: Resolving address of ftp.epizy.com
Status: Connection established, waiting for welcome message…
Response: 220---------- Welcome to Pure-FTPd [privsep] [TLS] ----------
Response: 220-You are user number 739 of 6900 allowed.
Response: 220-Local time is now 21:43. Server port: 21.
Response: 220-This is a private system - No anonymous login
Response: 220 You will be disconnected after 60 seconds of inactivity.
Trace: CFtpLogonOpData::ParseResponse() in state 1
Trace: CFtpLogonOpData::Send() in state 2
Command: AUTH TLS
Response: 234 AUTH TLS OK.
Trace: CFtpLogonOpData::ParseResponse() in state 2
Status: Initializing TLS…
Trace: tls_layer_impl::client_handshake()
Trace: tls_layer_impl::continue_handshake()
Trace: TLS handshakep: About to send CLIENT HELLO
Trace: TLS handshakep: Sent CLIENT HELLO
Trace: tls_layer_impl::on_send()
Trace: tls_layer_impl::on_read()
Trace: TLS handshakep: Received SERVER HELLO
Trace: TLS handshakep: Processed SERVER HELLO
Trace: TLS handshakep: Received CERTIFICATE
Trace: TLS handshakep: Processed CERTIFICATE
Trace: TLS handshakep: Received SERVER HELLO DONE
Trace: TLS handshakep: Processed SERVER HELLO DONE
Trace: TLS handshakep: About to send CLIENT KEY EXCHANGE
Trace: TLS handshakep: Sent CLIENT KEY EXCHANGE
Trace: TLS handshakep: About to send FINISHED
Trace: TLS handshakep: Sent FINISHED
Trace: TLS handshakep: Received NEW SESSION TICKET
Trace: TLS handshakep: Processed NEW SESSION TICKET
Trace: TLS handshakep: Received FINISHED
Trace: TLS handshakep: Processed FINISHED
Trace: TLS Handshake successful
Trace: Protocol: TLS1.2, Key exchange: RSA, Cipher: AES-256-GCM, MAC: AEAD, ALPN:
Trace: tls_layer_impl::verify_certificate()
Trace: System trust store decision: false
Trace: Hostname does not match certificate SANs
Trace: Sending certificate_verification_event
Trace: CFtpControlSocket::SetAsyncRequestReply
Trace: set_verification_result(true)
Status: TLS connection established.
Command: USER Ifo_35036777
Response: 331 User Ifo_35036777 OK. Password required
Command: PASS **************
Trace: CRealControlSocket::DoClose(1094)
Trace: CControlSocket::DoClose(1094)
Trace: CFileZillaEnginePrivate::ResetOperation(1094)
I have no idea what a lot of this means, any more suggestions, but please keep them simple
This is most likely the issue. The prefix is not Ifo, it is if0 (with a small i and the number 0).
Please enter your credentials exactly as shown on the client area.
Further to above—
For Oxy (Moderator) re your queries at bottom of yr message
URL brianlangley.id.au hosting username Ifo_35036777,. and sorry, but I’ve no idea what MonstaFTP is so I don’t know if it connected or not
FileZilla, router etc still set up from when successfully FTPing files to previous hosting service
Thanks all for suggestions
Hooray Success
BIG Thanks ChriPAR twas me all along putting in wrong info #@##@## zeros and Os and auto mistake making keyboards
It is “our” web-based FTP client that you can call if you click on this button
