Flarum forum not opening fully after enablng secure ssl
it ask to hard refresh but not loading full website after enabling secure ssl…
all things done automatically… what could be the solution?
Mixed content!
When HTTPS is used, all resources should be requested via the HTTPS protocol and not via HTTP.
Since you’re using Flarum, you might need to try this guide, following only Part 3:
For the rest I don’t know if I can help because I didn’t use Flarum for a while.
thanks …its done , now working … just replaced http with https:// in config file
