Fix thie
http://nectodevs.ga
Forbidden
You don’t have permission to access /panel/indexpl.php on this server.
So i was just on my phone making a error pages then that message popped out i keep trying and trying it just says that message i tried relogging in nothing just works i cant make a error page
Hi and welcome to the forum
seems to be working fine (error pages)
besides, why edit error pages when your WordPress takes care of it ?
and it’s better to let WP do it
because in case of a problem it generates pages that can help you fix the problem
yeah seems ok, no errors
Where did you see that error and after doing what? And I don’t think if you need to setup error pages since you are using wordpress.
oh ok thanks
I know Softaculous complains if there is already a .htaccess file
to not accidentally overwrite the existing one during some installation
for the control panel I’m not sure :slight_smile:
but,
you are somewhat lucky that the control panel threw out that error
and you were not able to edit .htaccess to redirect error pages (via the control panel )
because it could easily happen to break your WP
if something is written incorrectly in .htaccess of WP
