Fix Site Builder?
Will there ever be any fix for the Kopage Site Builder? At this point, it doesn’t work and its not just you as a web provider that it doesn’t work for, it doesn’t work for any iFastNet resellers either.
Problem: It uploads to FTP. It redirects to a blank page. I go to the site, its a blank page. if you want to check: jenovaonline.ml
It’s a blank page right? Its funny, because I used the first template available to me.
Shouldn’t be a blank page. I think its a configuration issue on iFastNet’s end.
But then again, they are dealing with enough so…will this ever be fixed?
Also, as a suggestion, SitePad is wonderful and I really like using it. There are other web hosts that use this, and I would love to have it here as well.
I’m pretty sure this is just Kopage being poorly engineered. We investigated running our own instance, but it gave us a lot of trouble.
Doing something with the site builder is on both our todo list and the one of iFastNet. I believe SitePad is already on the table as an option, but I don’t know the current status.
So, to answer your question, no, there may not be a fix for the Kopage Site Builder. But we would like to provide a good, reliable website builder.
Alright! Now I can rest easy.With VimlyHost shuttering it’s Free teir, you guys are my next option. Thanks!
