File Upload not possible
https://cl24h.kesug.com/
File Upload of any kind not possible.
“Unexpected response from the server. The file may have been uploaded successfully. Check in the Media Library or reload the page.”
The Images are around 150k
Backup and Restore with UpdraftPlus the same…
What can I do?
Uploads are probably failing because of an open incident on our status page, not because of your site or the size of your images. Since 21 Oct, multipart/form-data POST requests are being blocked on the hosting, and that is how file uploads are sent. iFastNet has blocked them as a security measure until a fixed PHP version is rolled out to all servers.
The incident says this affects all accounts, and that WordPress is one of the pieces of software that can be hit. It says forms with file uploads are the most notable ones to fail. Uploading to the Media Library and restoring a backup with UpdraftPlus both work that way.
The incident page has the current status and will show when the block is lifted:
I haven’t found anything you can change on your side to get around the block.
I don’t know what system your using to build your site. But if you’re trying to upload anything through an editor (like wordpress or MediaWiki, you may have some problems at the moment.
Please see the banner at the top of the page, and the status page:
Thanks Dan… it’s working right now, and I’m done with
