File Manager Problem
**My website URL is:http://mongoo.ga/
What I’m seeing is:
Monsta FTP
Error! There was an error creating FOLDER: Error during FTP MAKE_DIRECTORY_OPERATION, file not found: “/htdocs/Test”
Filezilla
227 Entering Passive Mode (***,69,124)
Komut: STOR cx<zczxcz
Yanıt: 553 Can’t open that file: Disk quota exceeded
Hata: Ciddi dosya aktarım sorunu
Delete files or folders you do not need.
Else you need to upgrade to premium hosting
This probably means you’ve exceeded the inode limit. You can only have up to 30,000 files and directories on a single account. If you hit that limit, you cannot create any more.
I didn’t exceed the 5GB file limit?
Can you screenshot:
  • how many inodes you’ve used (in vPanel, side panel labeled “Inodes used”)
  • the disk space you’ve used (also can be found in vPanel, “account statistics” at the bottom)
Thanks!
You didn’t. You have reached the limit of ~30k file limit.
