hi i have an problem with the file manager. Like when i open it it says Login (i have already created an acc on infinityfree) and i have no idea what to type in initial directory and what to do with the ip port and so on
Please reset the password of your account using the āEdit Accountā button in the client area. Wait 10 minutes for the changes to sync before trying again.
and then i shall try again? btw im using filezilla
Yes, after you wait 10 minutes then try again. Make sure you are using the password found under FTP in the client area!
btw do u use filezila too?
If there is an error, using FileZilla would be appreciated so we can collect useful errors.
It looks like FileZilla is working fine. Just drag and drop a file over to start an upload. And yes, I do use FileZilla.
but shouldnt the file manager (web) work too?
Not always, that is why FileZilla is recomended.
and how do i know that the web is working
If you use the web version to upload a file, you can then connect with FileZilla and see if the is present.
the filezilla sayd something succesful but the online file manager still have the login screen
Then just avoid using the online file manager, especially if FileZilla is working.
Can you please share the full logs from FileZilla?
FileZilla is much better than the online manager, so if it is working, just use it anyway.
Status: Connecting to 185.27.134.11:21...
Status: Connection established, waiting for welcome messageā¦
Status: Initializing TLSā¦
Status: Verifying certificateā¦
Status: TLS connection established.
Command: USER epiz_30743613
Response: 331 User epiz_30743613 OK. Password required
Command: PASS ********
Response: 530 Login authentication failed
Error: Critical error: Could not connect to server
Status: Disconnected from server
Status: Connecting to 185.27.134.11:21ā¦
Status: Logged in
Status: Retrieving directory listingā¦
Status: Directory listing of ā/ā successful
Status: Retrieving directory listing of ā/htdocsāā¦
Status: Directory listing of ā/htdocsā successful
Status: Logged in
Status: Starting download of /htdocs/files for your website should be uploaded here!
Status: File transfer successful, transferred 0 bytes in 1 second
Response: 421 Timeout - try typing a little faster next time
Error: GnuTLS error -110 in gnutls_record_recv: The TLS connection was non-properly terminated.
Status: Server did not properly shut down TLS connection
Error: Could not read from socket: ECONNABORTED - Connection aborted
Error: Disconnected from server
Status: Logged in
Status: Logged in
Status: Starting upload of C:\xampp\htdocs\login\Contacts.php
Status: Starting upload of C:\xampp\htdocs\login\connection.php
Status: Retrieving directory listing of ā/htdocs/logināā¦
Status: File transfer successful, transferred 909 bytes in 1 second
Status: Starting upload of C:\xampp\htdocs\login\functions.php
Status: File transfer successful, transferred 623 bytes in 1 second
Status: Starting upload of C:\xampp\htdocs\login\Games.php
Status: File transfer successful, transferred 201 bytes in 1 second
Status: Starting upload of C:\xampp\htdocs\login\login.php
Status: File transfer successful, transferred 912 bytes in 1 second
Status: Starting upload of C:\xampp\htdocs\login\Logo.png
Status: File transfer successful, transferred 2,225 bytes in 1 second
Status: Starting upload of C:\xampp\htdocs\login\logout.php
Status: File transfer successful, transferred 5,435 bytes in 1 second
Status: Starting upload of C:\xampp\htdocs\login\MainIndex.php
Status: File transfer successful, transferred 140 bytes in 1 second
Status: Starting upload of C:\xampp\htdocs\login\signup.php
Status: File transfer successful, transferred 1,123 bytes in 1 second
Status: Starting upload of C:\xampp\htdocs\login\Css\styles.css
Status: File transfer successful, transferred 2,178 bytes in 1 second
Status: Starting upload of C:\xampp\htdocs\login\My web\Contacts.html
Status: Retrieving directory listing of ā/htdocs/login/Cssāā¦
Status: Retrieving directory listing of ā/htdocs/login/My webāā¦
Status: File transfer successful, transferred 1,205 bytes in 1 second
Status: Starting upload of C:\xampp\htdocs\login\My web\Games.html
Status: File transfer successful, transferred 821 bytes in 1 second
Status: Starting upload of C:\xampp\htdocs\login\My web\MainIndex.html
Status: File transfer successful, transferred 822 bytes in 1 second
Status: Starting upload of C:\xampp\htdocs\login\My web\Css\styles.css
Status: File transfer successful, transferred 824 bytes in 1 second
Status: Creating directory ā/htdocs/login/My web/Jsāā¦
Status: Retrieving directory listing of ā/htdocs/login/My web/Cssāā¦
Status: File transfer successful, transferred 1,298 bytes in 1 second
Status: Logged in
Status: Directory listing of ā/htdocs/loginā successful
idk how long was that ago tho
