File_get_contents hosting disable problem
http://iddaatahmin.epizy.com
TR : file_get_contents fonksiyonu aktif değil! Sunucu yönetimi ile iletişime geçin file_get_contents fonksiyonunu aktif etmelerini rica ediniz.
EN : file_get_contents helper not active! Go with the server management and ask them to activate the file_get_contents function.
How can I solve the problem and activate?
The PHP file_get_contents is enabled on this hosting. You may to need to contact the developer of the software your using and say to them it is enabled.
