https://aerolabssim.com
im not sure why the Favicon only shows up for HTTP and not HTTPS
Because you served favicon over insecure http, so when you load site over https all insecure http calls has been blocked. All content must be served over https
Hello
I recommend that you force all traffic to HTTPS, then change all http:// links in your code to https://
After you’ve enabled SSL for your website, you’ll probably want to redirect all traffic on your website to the https version of your site. There are multiple ways to do that. Let’s compare some commonly used ways.
Using script configuration
Some scripts (including Wordpress) have a setting which allows you to set your website URL. By changing this URL from http://example.com to https://example.com , the script will probably redirect visitors to the https version of your site. Even if your script…
