Failed to send data from php code via AJAX and JSON response does not come
https://www.e-procedure.wuaze.com
please need your help because my site cannot save the data provided by the users of my site in the database and their image does not migrate into the specified folder, but my site worked well with the local wampserver server and all the code worked. As a result I find these errors in the browser console:
1: syntaxError: unexpected end JSON imput
2: Failed to load recourse: the server responded with a status of 500()
3: POST https://www.e-procedure.wuaze.com/php/upload.php net::ERR_ABORTED 500 (internal server error).
Need help please
Enable error logs and try again please
how to activity error logs
From that article:
I can’t activate the error logs because when I press modify php directives nothing happens. what is this due to?
hello I can’t modify the php configuration and activate the error logs, so when I press modify configuration nothing happens.
Perhaps you should continue to read on
