Failed to load resource:
net::ERR_CONNECTION_REFUSED
Some of the videos and photos cannot be loaded and the console window said it was ERR_CONNECTION_REFUSED
That’s because your resource is pointing to http://localhost/deliscoffeeph
It shd be deliscoffeeph.com instead.
You need to change all http://localhost/deliscoffeeph instances to deliscoffeeph.com
Thank you so much for the response. How should I change the resources? It is a wordpress website built with Elementor.
You need to change the local copy of your database. Then upload thru PHPMyAdmin
This link may help
I had to reselect the image on the image picker and it worked! Thanks for these tips
Welcome
