Every POST request returns 403 Forbidden (openresty), GET works — dieta.gt.tc
https://dieta.gt.tc
403 Forbidden – openresty (on every POST request; GET requests work normally)
Since 21 Oct 2026 (~12:40 CEST) every POST request to my site returns “403 Forbidden – openresty”. GET requests work fine. It happens from different networks (home Wi-Fi and another location), so it doesn’t seem to be my IP.
To prove it isn’t my code, I created a test file: https://dieta.gt.tc/prueba_post.php
It always prints {“llega”:true}.
  • GET to it → 200 with that JSON.
  • POST to it with a tiny form (2 fields) → 403 openresty page, so the request never reaches PHP.
It also happens with my .htaccess removed. Everything worked fine until 20 Oct.
Account username: if0_41999509
Could you please check whether my account or domain was flagged and lift the block? Thank you!
Your account hasn’t been flagged. This matches an open incident on our status page: POST requests using multipart/form-data are currently being blocked before they reach PHP, on all accounts.
The incident says the block is there because of two severe PHP security issues. The fixed PHP packages haven’t been released yet. Until they are published and rolled out on all hosting servers, iFastNet is blocking certain requests from reaching PHP, including all multipart/form-data POSTs. That’s why your test file never runs on a POST.
The incident also says POSTs using form-urlencoded data are not affected. Forms that send application/x-www-form-urlencoded should still work. If your test form or your site’s forms use multipart/form-data (the default for file uploads, or when enctype="multipart/form-data" is set), that would explain the 403s. Sending the same two fields as urlencoded would show whether that’s the case.
Here is the incident, with its updates:
Welcome to the forum
I’m going to assume you’ve read the banner at the top of the page that explains this?
The link the bot posted:
will give you more details
This has been done by IFastNet (who provide the infrastructure that InfinityFree is built on) to mitigate some major security vulnerabilities in the current PHP version. Once they’ve been able to update the PHP version, this restriction should be lifted.
All we have to do is to wait for them to fix it.
