This page isn’t working
supertechrockers.ga redirected you too many times.
ERR_TOO_MANY_REDIRECTS
Thank you. These are the actually relevant parts.
Did you setup your website exactly as described in this article? Redirect loops are a common symptom of WordPress+Cloudflare configuration issues:
Thank you for the response but now I am unable to access my control panel
I get this error(it was working fine till yesterday) in vista panel-
Your password is too short! please use a minimum of 6 characters and a maximum of 20.Back
Is most likely due to this…
YAY!Thank you all for the solution Cloudfare is working alright NOW!!
But still, my sitemap is not validated my google so I have contacted Rank math support again and they returned with this-
"Hello,
"We’ve checked your site for that issue, and you have several versions, so we’d suggest you consolidate all versions of your website and only use one version.
Please see screenshot below:
Once you’ve done that it should fix the issue.
I hope that helps. Let us know if you need help with anything else.
Thank you."
How to fix this?
