The domain resolves successfully to IP address 185.27.134.127, but:
HTTP (port 80): TCP connection failed.
HTTPS (port 443): TCP connection failed.
The website returns ERR_CONNECTION_TIMED_OUT.
The issue occurs on both my home Wi-Fi and mobile data.
DNS lookup works successfully.
This issue started after I uploaded some files for a Web Push Notification implementation, although I have already disabled the newly created .htaccess files.
Could you please check whether there is an issue with the server, network routing, or my hosting account?
A timeout on ports 80 and 443 happens before the web server reads any of your files. So I don’t think the .htaccess files are the cause. A bad .htaccess normally gives an error page like a 500, not a connection that never completes.
Can you tell me whether FTP still works? Try connecting with your FTP client, and also try opening the file manager. Our article on hosting volumes says that if the website and FTP both fail, it’s most likely a hosting volume problem. If only the website fails, the cause is more likely the web server behind your IP address.
