Error showing in admin panel and website not showing correct
Website → cnphotography.epizy.com
Error Message:
RegExp constructor can alter flags and IsRegExp works correct with @@match return $RegExp(re1) != re1…and other similar stuff
This error is showing since yesterday. I thought it was a pluging, but disabled and uninstalled most that were used during that period.
Can you share where this error is? Your homepage seems to be working fine for me.
sorry but as a new user it says i can’t add more than 2 links and the error contains more
Type the key to the left of the “1” key three times, press the “enter” key, paste the error message, press the “enter” key again, then tap the key to the left of the “1” three times again. It should look something like this.
Thanks
Error message here
uire__(/*! ./_wks */ "../node_modules/core-js/modules/_wks.js")('match')] = false; // RegExp constructor can alter flags and IsRegExp works correct with @@match return $RegExp(re1) != re1 || $RegExp(re2) == re2 || $RegExp(re1, 'i') != '/a/i'; }))) { $RegExp = function RegExp(p, f) { var tiRE = this instanceof $RegExp; var piRE = isRegExp(p); var fiU = f === undefined; return !tiRE && piRE && p.constructor === $RegExp && fiU ? p : inheritIfRequired(CORRECT_NEW ? new Base(piRE && !fiU ? p.source : p, f) : Base((piRE = p instanceof $RegExp) ? p.source : p, piRE && fiU ? $flags.call(p) : f) , tiRE ? this : proto, $RegExp); }; var proxy = function (key) { key in $RegExp || dP($RegExp, key, { configurable: true, get: function () { return Base[key]; }, set: function (it) { Base[key] = it; } }); }; for (var keys = gOPN(Base), i = 0; keys.length > i;) proxy(keys[i++]); proto.constructor = $RegExp; $RegExp.prototype = proto; __webpack_require__(/*! ./_redefine */ "../node_modules/core-js/modules/_redefine.js")(global, 'RegExp', $RegExp); } __webpack_require__(/*! ./_set-species */ "../node_modules/core-js/modules/_set-species.js")('RegExp'); /***/ }), /***/ "../node_modules/core-js/modules/es6.regexp.exec.js": /*!**********************************************************!*\ !*** ../node_modules/core-js/modules/es6.regexp.exec.js ***! \**********************************************************/ /*! unknown exports (runtime-defined) */ /*! runtime requirements: __webpack_require__ */ /***/ ((__unused_webpack_module, __unused_webpack_exports, __webpack_require__) => { "use strict"; var regexpExec = __webpack_require__(/*! ./_regexp-exec */ "../node_modules/core-js/modules/_regexp-exec.js"); __webpack_require__(/*! ./_export */ "../node_modules/core-js/modules/_export.js")({ target: 'RegExp', proto: true, forced: regexpExec !== /./.exec }, { exec: regexpExec }); /***/ }), /***/ "../node_modules/core-js/modules/es6.regexp.flags.js": /*!***********************************************************!*\ !*** ../node_modules/core-js/modules/es6.regexp.flags.js ***! \***********************************************************/ /*! unknown exports (runtime-defined) */ /*! runtime requirements: __webpack_require__ */ /***/ ((__unused_webpack_module, __unused_webpack_exports, __webpack_require__) => { // 21.2.5.3 get RegExp.prototype.flags() if (__webpack_require__(/*! ./_descriptors */ "../node_modules/core-js/modules/_descriptors.js") && /./g.flags != 'g') __webpack_require__(/*! ./_object-dp */ "../node_modules/core-js/modules/_object-dp.js").f(RegExp.prototype, 'flags', { configurable: true, get: __webpack_require__(/*! ./_flags */ "../node_modules/core-js/modules/_flags.js") }); /***/ }), /***/ "../node_modules/core-js/modules/es6.regexp.match.js": /*!***********************************************************!*\ !*** ../node_modules/core-js/modules/es6.regexp.match.js ***! \***********************************************************/ /*! unknown exports (runtime-defined) */ /*! runtime requirements: __webpack_require__ */ /***/ ((__unused_webpack_module, __unused_webpack_exports, __webpack_require__) => { "use strict"; var anObject = __webpack_require__(/*! ./_an-object */ "../node_modules/core-js/modules/_an-object.js"); var toLength = __webpack_require__(/*! ./_to-length */ "../node_modules/core-js/modules/_to-length.js"); var advanceStringIndex = __webpack_require__(/*! ./_advance-string-index */ "../node_modules/core-js/modules/_advance-string-index.js"); var regExpExec = __webpack_require__(/*! ./_regexp-exec-abstract */ "../node_modules/core-js/modules/_regexp-exec-abstract.js"); // @@match logic __webpack_require__(/*! ./_fix-re-wks */ "../node_modules/core-js/modules/_fix-re-wks.js")('match', 1, function (defined, MATCH, $match, maybeCallNative) { return [ // `String.prototype.match` method // https://tc39.github.io/ecma262/#sec-string.prototype.match function match(regexp) { var O = defined(this); var fn = regexp == undefined ? undefined : regexp[MATCH]; return fn !== undefined ? fn.call(regexp, O) : new RegExp(regexp)[MATCH](String(O)); }, // `RegExp.prototype[@@match]` method // https://tc39.github.io/ecma262/#sec-regexp.prototype-@@match function (regexp) { var res = maybeCallNative($match, regexp, this); if (res.done) return res.value; var rx = anObject(regexp); var S = String(this); if (!rx.global) return regExpExec(rx, S); var fullUnicode = rx.unicode; rx.lastIndex = 0; var A = []; var n = 0; var result; while ((result = regExpExec(rx, S)) !== null) { var matchStr = String(result[0]); A[n] = matchStr; if (matchStr === '') rx.lastIndex = advanceStringIndex(S, toLength(rx.lastIndex), fullUnicode); n++; } return n === 0 ? null : A; } ]; }); /***/ }), /***/ "../node_modules/core-js/modules/es6.regexp.replace.js": /*!*************************************************************!*\ !*** ../node_modules/core-js/modules/es6.regexp.replace.js ***! \*************************************************************/ /*! unknown exports (runtime-defined) */ /*! runtime requirements: __webpack_require__ */ /***/ ((__unused_webpack_module, __unused_webpack_exports, __webpack_require__) => { "use strict"; var anObject = __webpack_require__(/*! ./_an-object */ "../node_modules/core-js/modules/_an-object.js"); var toObject = __webpack_require__(/*! ./_to-object */ "../node_modules/core-js/modules/_to-object.js"); var toLength = __webpack_require__(/*! ./_to-length */ "../node_modules/core-js/modules/_to-length.js"); var toInteger = __webpack_require__(/*! ./_to-integer */ "../node_modules/core-js/modules/_to-integer.js"); var advanceStringIndex = __webpack_require__(/*! ./_advance-string-index */ "../node_modules/core-js/modules/_advance-string-index.js"); var regExpExec = __webpack_require__(/*! ./_regexp-exec-abstract */ "../node_modules/core-js/modules/_regexp-exec-abstract.js"); var max = Math.max; var min = Math.min; var floor = Math.floor; var SUBSTITUTION_SYMBOLS = /\$([$&`']|\d\d?|<[^>]*>)/g; var SUBSTITUTION_SYMBOLS_NO_NAMED = /\$([$&`']|\d\d?)/g; var maybeToString = function (it) { return it === undefined ? it : String(it); }; // @@replace logic __webpack_require__(/*! ./_fix-re-wks */ "../node_modules/core-js/modules/_fix-re-wks.js")('replace', 2, function (defined, REPLACE, $replace, maybeCallNative) { return [ // `String.prototype.replace` method // https://tc39.github.io/ecma262/#sec-string.prototype.replace function replace(searchValue, replaceValue) { var O = defined(this); var fn = searchValue == undefined ? undefined : searchValue[REPLACE]; return fn !== undefined ? fn.call(searchValue, O, replaceValue) : $replace.call(String(O), searchValue, replaceValue); }, // `RegExp.prototype[@@replace]` method // https://tc39.github.io/ecma262/#sec-regexp.prototype-@@replace function (regexp, replaceValue) { var res = maybeCallNative($replace, regexp, this, replaceValue); if (res.done) return res.value; var rx = anObject(regexp); var S = String(this); var functionalReplace = typeof replaceValue === 'function'; if (!functionalReplace) replaceValue = String(replaceValue); var global = rx.global; if (global) { var fullUnicode = rx.unicode; rx.lastIndex = 0; } var results = []; while (true) { var result = regExpExec(rx, S); if (result === null) break; results.push(result); if (!global) break; var matchStr = String(result[0]); if (matchStr === '') rx.lastIndex = advanceStringIndex(S, toLength(rx.lastIndex), fullUnicode); } var accumulatedResult = ''; var nextSourcePosition = 0; for (var i = 0; i < results.length; i++) { result = results[i]; var matched = String(result[0]); var position = max(min(toInteger(result.index), S.length), 0); var captures = []; // NOTE: This is equivalent to // captures = result.slice(1).map(maybeToString) // but for some reason `nativeSlice.call(result, 1, result.length)` (called in // the slice polyfill when slicing native arrays) "doesn't work" in safari 9 and // causes a crash (https://pastebin.com/N21QzeQA) when trying to debug it. for (var j = 1; j < result.length; j++) captures.push(maybeToString(result[j])); var namedCaptures = result.groups; if (functionalReplace) { var replacerArgs = [matched].concat(captures, position, S); if (namedCaptures !== undefined) replacerArgs.push(namedCaptures); var replacement = String(replaceValue.apply(undefined, replacerArgs)); } else { replacement = getSubstitution(matched, S, position, captures, namedCaptures, replaceValue); } if (position >= nextSourcePosition) { accumulatedResult += S.slice(nextSourcePosition, position) + replacement; nextSourcePosition = position + matched.length; } } return accumulatedResult + S.slice(nextSourcePosition); } ]; // https://tc39.github.io/ecma262/#sec-getsubstitution function getSubstitution(matched, str, position, captures, namedCaptures, replacement) { var tailPos = position + matched.length; var m = captures.length; var symbols = SUBSTITUTION_SYMBOLS_NO_NAMED; if (namedCaptures !== undefined) { namedCaptures = toObject(namedCaptures); symbols = SUBSTITUTION_SYMBOLS; } return $replace.call(replacement, symbols, function (match, ch) { var capture; switch (ch.charAt(0)) { case '$': return '$'; case '&': return matched; case '`': return str.slice(0, position); case "'": return str.slice(tailPos); case '<': capture = namedCaptures[ch.slice(1, -1)]; break; default: // \d\d? var n = +ch; if (n === 0) return match; if (n > m) { var f = floor(n / 10); if (f === 0) return match; if (f <= m) return captures[f - 1] === undefined ? ch.charAt(1) : captures[f - 1] + ch.charAt(1); return match; } capture = captures[n - 1]; } return capture === undefined ? '' : capture; }); } }); /***/ }), /***/ "../node_modules/core-js/modules/es6.regexp.split.js": /*!***********************************************************!*\ !*** ../node_modules/core-js/modules/es6.regexp.split.js ***! \***********************************************************/ /*! unknown exports (runtime-defined) */ /*! runtime requirements: __webpack_require__ */ /***/ ((__unused_webpack_module, __unused_webpack_exports, __webpack_require__) => { "use strict"; var isRegExp = __webpack_require__(/*! ./_is-regexp */ "../node_modules/core-js/modules/_is-regexp.js"); var anObject = __webpack_require__(/*! ./_an-object */ "../node_modules/core-js/modules/_an-object.js"); var speciesConstructor = __split logic __webpack_require__(/*! ./_fix-re-wks */ "../node_modules/core-js/modules/_fix-re-wks.js")('split', 2, function (defined, SPLIT, $split, maybeCallNative) { var internalSplit; if ( 'abbc'[$SPLIT](/(b)*/)[1] == 'c' || 'test'[$SPLIT](/(?:)/, -1)[LENGTH] != 4 || 'ab'[$SPLIT](/(?:ab)*/)[LENGTH] != 2 || '.'[$SPLIT](/(.?)(.?)/)[LENGTH] != 4 || '.'[$SPLIT](/()()/)[LENGTH] > 1 || ''[$SPLIT](/.?/)[LENGTH] ) { // based on es5-shim implementation, need to rework it internalSplit = function (separator, limit) { var string = String(this); if (separator === undefi
Try re-installing WP (Take a backup first)
