Error Please Help
This is what happened -
1.First I change my name servers to infinityfree and built a website
2.Then I tried to use cloudflare I changed my nameserver again to cloudflare’s
3.now I want to change back to infinityfree but when I tried it said name servers are not pointing towards our server but all the name server are correct and pointing towards them please help.
Hi,
It usually takes up to 24 hrs for the dns to fully take effect. Pls wait a little bit more.
Like @UnknownLolz said, you probably just have to wait a bit longer for the nameservers to update.
If that doesn’t work, can you please share your domain name so we can check if the settings are correct?
