[### Username (e.g. epiz_XXX) or Website URL]
epiz_32307260
(http://fundicionblanco.infinityfreeapp.com/ )
Plugin JoinChat for WordPress doesn’t work
GET https://errors.infinityfree.net/403/ net::ERR_ABORTED 403 admin.php:2166
Line 2166:
I tried to use the JoinChat plugin for my WP website, but it doesn’t run properly as it seems like the code is being blocked. If there is a way to configure it to use it, I hope you can support me.
Hello!
Unfortunately, live chat scripts are banned and cannot be used on InfinityFree.
For more info:
Getting a 403 error means the server is refusing to show your webpage. Here are the most common causes and how to fix them:
1. Website Files Are in the Wrong Location
The Issue: Your domain might be pointing to an empty or non-existent folder.
How to Check:
Log into your InfinityFree client area
Go to Accounts → [Select your account] → Domains → [Find your domain] → Manage
Find the Directory Status card, and look at the Directory displayed there
Understanding the folder structure:
Your fi…
