Error establishing database connection when i try oppening my site
User name: epiz_29547969
Iam getting the same message when i try to get in the website
@anon68009225, welcome to the forum!
There seems to be some problem with the database server or an outage. Please have patience till it has been resolved!
Ok thanks …still giving this message
This either means that the username and password information in your wp-config.php file is incorrect or we can’t contact the database server at sql208.byetcluster.com. This could mean your host’s database server is down.
  • Are you sure you have the correct username and password?
  • Are you sure you have typed the correct hostname?
  • Are you sure the database server is running?
If you’re unsure what these terms mean you should probably contact your host. If you still need help you can always visit the WordPress Support Forums.
It will! There is an outage!
Please read this:
