Error establishing connection with database
arman.com.np
Although all file are there still getting Error establishing connection with database
Please add this line
define( 'WP_DEBUG', true );
to wp-config.php to enable debug mode and then we can further determine the issue.
For general info on MySQL databases please see
i have added that line
With debug mode enabled, what’s the error message you see now? And can you find that error message in the Common Errors article linked above?
site is now running but i am getting a lot of msg on top can you check once
also all other pager are throwing 500 error
We don’t see the errors you’re facing:
You’ll need to copy and paste them here.
I think i may know why its happening, are you using elementor? If yes get rid of it, because on free hosting is terrible I suggest Spectra, cheers
