Boggames.page.gd
:This site can’t be reached
Check if there is a typo in boggames.page.gd
DNS_PROBE_FINISHED_NXDOMAIN
It is not available
Boggames.page.gd
It is not available
Your website is working fine from here.
Is the domain name less than 72 hours old? Then this is most likely just DNS propagation, and it will solve itself automatically within a few days at most.
If the domain is more than 72 hours old, then it may be caused by the domain name being blocked on your end. This can happen due to a network security filter or firewall of some kind. Please try to see if you can access the website from a different device or network to help narrow down where the blocking might be happening.
No its been like 4 months
Its not showing up on locations near my house
Its working fine for me too. This would suggest that your ISP may be blocking the domain.
Exact physical location has very little do to with these kinds of issues. They are network level issues, and those do not align perfectly with geographical locations.
If you cannot view the website from your house on mobile data, then walking down the street will not change anything. You might still be connected to the same cell tower, and even if you aren’t, the block is usually deeper in the provider’s network, not limited to specific towers.
The blocks can be caused by network level blocks at your ISP (meaning that everyone on the same ISP is affected in the same way), but it could also be limited to your specific network (especially on restricted networks like education or corporate networks), and they could even be caused by antivirus software running on your computer itself.
my website is down now
Your InfinityFree account if0_41873555 (boggames.page.gd owner) has been temporarily suspended.
Your account was suspended because you hit the Entry Process limits.
To learn more about the limits, please check the knowledge base articles about the Entry Process limits.
Accounts that hit a daily limit are suspended for 24 hours. After 24 hours, your account will be reactivated automatically.
Your account will be reactivated automatically in 24 hours from now.
Please evaluate your website and consider taking actions that may reduce your account’s resource usage. Accounts that repeatedly hit limits may get taken down permanently.
and,no it didnt work with a person with a diffent isp(i forgot to send this messgae)
I’m not sure what else I can tell you. The domain is fully up and is reachable from all over the world. I cannot explain the issue that you’re having, but based on my best guess, even if I did, I don’t think it’s a problem we can fix from our end.
Did you also try what @Meishin recommended in the very first reply you got?
yeah and i also reinstalled wp and all my files but there is a undeletable folder in my filemanager named vol1_1/infinityfree.com/if0_41873555/htdocs/Events/storage/app/publicvol1_1/infinityfree.com/if0_41873555/htdocs/Events/storage/app/publicvol1_1/infinityfree.com/if0_41873555/htdocs/Events/storage/app/publicvol1_1/infinityfree.com/if0_41873555/htdocs/Events/storage/app/public it is not deletable
and its still down for me…
I would be more surprised if it did start working now. My previous message still applies though.
It possible to create files with PHP that cannot be deleted or accessed via FTP, including the file manager (which is also just an FTP client). The fix is to delete it via FTP.
But before we dive into that, let’s focus on the more urgent issue of your website not being reachable.
And just to let you know: I see no reason to believe that doing anything on your website itself will affect this issue, including reinstalling WordPress.
i have ![]()
… you have what?
I would like to help you, but you actually need to start writing messages and describing things. This pattern of copy-pasting error messages and stating that it doesn’t work is clearly not getting us closer to solving this.
Have you tried to use a VPN?
