Admin
July 19, 2023, 9:40am
21
Seeing how you’re using WordPress, you’ll need to update the website URL of your site in the WordPress admin area. The setting can be found in the Settings → General menu.
You’ll want to request and install a new SSL certificate for your new domain. You can do so with the Free SSL Certificates tool.
Every SSL certificate has the domain name it’s valid for baked into the certificate, so it’s not possible to “move” a certificate to a new domain.
Thank you very mych for your advice.
After changing the website url at wordpress settings I wanted to generate new certificate - and there additional questions:
Which provider should I choose? Is there any manual to read about? Or just leave defaults.
Is there any HowTo about setting certificates to external domains?
cyfrowyodkrywca:
Leave it as default
If you need manuals then please read these
If you want an SSL certificate that’s trusted by browsers, it must be provided by a known SSL certificate provider, also called Certificate Authority. InfinityFree integrates with multiple SSL providers, because different SSL providers are better suited for some circumstances. This article details the various options we support, and which we recommend for you.
Which SSL providers are available?
Let’s Encrypt
Let’s Encrypt is the world’s largest SSL certificate provider. Let’s Encrypt changed th…
In order to get a padlock in the address bar in your website, you need to install an SSL certificate on your website. This article describes how to do that.
If you would rather watch a video, scroll down to the bottom of this article.
Installing an SSL certificate
The first step to install an SSL certificate is of course to get the SSL certificate. You will need to get your SSL certificate from a certificate vendor of your choice. InfinityFree also provides free SSL certificates in the client …
After you’ve enabled SSL for your website, you’ll probably want to redirect all traffic on your website to the https version of your site. There are multiple ways to do that. Let’s compare some commonly used ways.
Using script configuration
Some scripts (including Wordpress) have a setting which allows you to set your website URL. By changing this URL from http://example.com to https://example.com , the script will probably redirect visitors to the https version of your site. Even if your script…
There’s no difference between “internal” or “external” domains, as you are on infinityfree ns. Just use what you have used to get a cert.
Thank you very much - I have managed to set my own domain with free SSL certificate.
system
Closed
July 30, 2023, 6:03pm
25
