Error 522 - Connection timed out (host error)
Hi Support, my site is showing a 522 Error - host error.
Domain = doucenoir.com
I have checked that my cloudflare dns points to 185.27.134.101 and it matches the IP for my hosting domain s7iwfvvf.epizy.com
https://gyazo.com/622ce5673252cec6e77d246d4ae167b8
The IP address 185.27.134.101 has been temporarily taken down due to a DDoS attack. Sadly, there is not much anyone can do about this until the attack is over.
If you’re in a hurry, you could create a new hosting account and move your website to it. The new hosting account would likely be assigned to a different IP address, which should let you serve your website from there.
Thanks for your reply. I will sit and wait. Now I can play with the cloudflare always on feature.
play with it for 48 hours lol
@shreejalmaharjan some of my pages had the Cache Control header set to ‘no-cache’ so my always-on would had failed on cloudflare side.
In these situations you can work on a solution to serve pages, rather than moan that something is down 48 hours and have it recurring in the future
