When contacting your hosting provider, share the following information:
The specific 5XX error code and message.
The time and timezone when the 5XX error occurred.
The URL that resulted in the HTTP 5XX error (for example, https://www.example.com/images/icons/image1.png).
The cause of the error is not always found in the origin server’s error logs. Be sure to check the logs of any load balancers, caches, proxies, or firewalls between Cloudflare and the origin web server.
Can you confirm where you are seeing these errors? I’m fairly sure 521 and 523 are cloudflare errors, but your site seems to be loading fine for me.
Also, I understand how tempting it is, but please dont just copy paragraphs from Co-pilot or ChatGPT when asking for help. It often has large amounts of incorrect or muddled up information, and doesn’t really let us help you
