Error 404 on my website, please help
404 Not Found - InfinityFree
My website is http://theonlypresenceisgod.com
I get error 404 when I click on the About Us page and other pages. But not all pages.
What can be the problem? I have re-upload more than four times—still the same issue.
Can anybody help to get rid of this error 404?
Thank you
This error comes up on about 4 pages on the website and some links are not working, other works:
Please read
Thank you for that explanation. But when I type [http://theonlypresenceisgod.com/aboutus.html](https://this works, but not when it is directly clicked on from main page)
it goes through without error. You can see it when you click on it.
Errors occurred only when I clicked on the page about us directly on the Home page.
It is baffling how that can be the case.
Thanks.
Yes because when you click from your site there is this url : https://theonlypresenceisgod.com/aboutUs.html look what is it aboutUs
And you gave us the correct url which is
http://theonlypresenceisgod.com/aboutus.html the correct is ===> aboutus <===
Fix your html code…
Specifically: please note that our servers are case sensitive. So aboutus.html and aboutUs.html are different file names, and cannot be used interchangeably.
