Main Website Does Not Connect And Just Shows:
But All My Sub Domains Work Fine
In Htdocs I Have A File Called index.html
This Problem Only Started Today
oceansiderp.online is working fine for me now. Do you still experience this issue?
Try clearing your cache:
Still Nothing
Checked On My Phone And My Backup Phone Same Issue
Account looks suspended
Can you please check your Cloudflare DNS records? You should have one A record pointing to the Website IP displayed in the client area. Any other records for oceansiderp.online of types A, AAAA, CNAME must be deleted (MX and TXT are fine).
Remove the last “wwww” A record.
Remove the CNAME record with the “*”
Add an A record pointing to “@“ with the contents of “185.27.134.34”
No, that’s not what I told you do. Please read my post and follow it.
You’ve already added that A record (as seen on your early screenshot).
Now (if you haven’t done it yet), remove the CNAME and the last A record as said by @Greenreader9.
Also remove the www 185.27.134.57 record as said by @KangJL.
