Please help me i do something that my website crush now.
I install and plugins in wordpress really SSL and now i can not acces to my /wp.admin/
appear me this error
please what i need to do?
hello again,
I already try everything to put my website secure http://fugirpt.infinityfreeapp.com/.
I already register in cloudfare the domain fugir.blog
and i already go to my domain try to change the nameservers, that doesnât allow me to change because i need to change the IP tooâŚ
is a problem of SSL?
Because in the domain they are selling me the ssl but they tell me that i need to do the instalation hereâŚ
Iâm confuse because donât know what to doâŚ
Have another way without cloudflare to put the website secure?
Thank you
Your website have ssl
Try to clear your browser cache and also check this topic How to force all trafic to https
yes the http://fugirpt.infinityfreeapp.com/ have, but iâm redirect to my eternal domain that is fugir.blog and this one donât have.
I already try to put a SSL in fugir.blog by hereâŚ
but both always appear me that are insecure⌠and i donât know whyâŚ
what i can do to fix this?
thank for your reply
Fugir.blog alao have ssl and itâs working
As I said try to clear your browser cache, also check the topic which I sented you.
Cheers!
Thank you again!
I will try to clear the browse cache now!
One question, i can not do with cloudflare, because i can not access to my dns on fugir.blog.
Can i force the https with a plugin on wordpress like Install the Really Simple SSL plugin?
Our i always need to do in cloudflare first?
Thank you
I donât understand you. Does your registrar disallows changing nameservers?
Read the guide @B0binch0 sent you. It contains useful information.
Thereâs also a community guide about WordPress specifically, donât know whether it helps or not:
In my domain account of my fugir.blog, i donât have the access to change nameserver.
And ask me from the nameserver (that i try do put the cloudflare nameserver) and ask me too for the IP, that i donât know how to putâŚ
Welll resume in my account of fugir.blog i not avaible to change nothing, to point something about cloudflare.
In the topic that you send me Forcing your wordpress, looking at my htaccess appear me that
Thank you
Right now, the problem is not that your website is not using HTTPS, but that it is trying to load content from fugirpt.infinityfreeapp.com. This is happening because your subdomain is still configured as the websiteâs URL; changing the setting to https://fugir.blog should solve the issues youâre seeing.
Hello Chris,
Thank you for the help, but i still donât know how to doâŚ
Iâm affraid to lost everythingâŚ
And i try to read your link, but some i donât undertand and some i try to search in the config⌠and doesnât appear me.
One question if i copy all the file in httpdocs and move the files to the folder of fugir.blog > httpdocs
this will solve my problem?
Is anything that i could do more easily?
Thank you
Would this guide be more helpful?
Only follow the âMethod 1: Change WordPress Site URLs From Admin Areaâ part, unless it does not work.
Just adding to what ChrisPAR said:
Because you donât. Not everything is pre-written in the config. The guide didnât say âChange these linesâ, it asks you to âAdd these linesâ.
That is to say, writing is not anything scary. If you can change a config, you can write a config.
*whisper* Itâs htdocs
If you are sure that fugir.blog locates in /fugir.blog/htdocs then you can try, but judging from your last post, I donât think fugir.blog use that folder, as you added it as a parked domain.
And one more thing:
The word âappearâ is not a drop-in replacement for the word âshowâ. While âshowâ is a transitive verb, âappearâ is not.
So thereâs simply not a phrase that looks like âappear somebody somethingâ. Thatâs wrong.
I do the change in method 1 and all crash downâŚ
I access to wordpress like i do (http://fugirpt.infinityfreeapp.com/) and i change like the method 1
the link to http://fugir-blog and all crash downâŚ
now what can i do?
Are you sure this is your domain?
Check again
How can I reverted the changes?
Where I need to go in ftp (config? function?) to edit and acess again like i do before http://fugirpt.infinityfreeapp.com/wp-admin
And replace again in the wordpress > setting to the link http://fugirpt.infinityfreeapp.com/ and not the http://fugir.blog
Like i said fugir.blog in a domain that i have outside that i only what ro redirect a website done in http://fugirpt.infinityfreeapp.com/ to the link domain fugir.blogâŚ
You site is working fine for me. Both the main page and the login page. With SSL enabled.
If you continue to see random errors, please try clearing your browser cache with Ctrl + F5. Or use incognito mode.
