username: epiz_28117283, websit url: tedllanes.gq
I had “ERR_SSL_PROTOCOL_ERROR” on my site but I already changed https —> http under mysql on table ‘wpdz_options’
I’m sure I migrated it properly because my previous account was under those unresponsive ip address that was under DDoS.
Please help…
KangJL
2
This is what I found
If you have uploaded your SSL cert, you may have to wait for SSL issue to resolve.
You can also disable SSL in the meantime and use CloudFlare instead
I disabled my ssl, I cannot used cloudfare and it seems like there has been a problem with ssls in infinityfree. Any more alternative solution?
KangJL
4
What about your .htaccess?
Did you disable the https forwarding?
Why not? Your domain should be eligible
