Epkstore.ir domain is not pointing to InfinityFree
Title: My .ir domain is not pointing to InfinityFree
Hello,
I recently added my .ir domain epkstore.ir to my InfinityFree hosting account and configured the InfinityFree nameservers.
However, the Health Check still shows this message:
Your domain name is not pointing to our server!
Your domain name is pointing to the IP address(es): 185.27.134.224.
Could you please check if my domain is correctly configured on your side and let me know if there is anything I need to change?
Domain: epkstore.ir
Thank you for your help.
Depending on how recently you made the changes you may just need to wait up to 3 days.
This is a community forum so we don’t have any more access than you do to check these things
All good now!
For the record, I didn’t do anything. This sounds to me like it was just DNS caching, and nothing was wrong in the first place.
Hello again,
My domain, epkstore.ir, is not opening. What could be the reason?
Opening fine for me, can you confirm what you’re seeing?
You don’t have an ssl certificate, so you will see a “connection is not private” error if you try and connect to https
Yes, the website opens when I use my ADSL modem connection, but it does not open when I use mobile data.
That sounds like your mobile ISP may be blocking access to your website.
What do you actually see when you try to access your website on mobile data? Do you get any specific error messages or error codes that could help to narrow this down?
Hello my friend,
No, I don’t receive any error message.
Is it possible to change the website’s IP address to see if that resolves the problem?
So what do you see then when you try to access your website on your phone?
No, moving websites to other IP addresses is not possible. However, you can create a second hosting account with a temporary subdomain to test it. That different account will probably get assigned to a different IP address.
Thank you
