E-mails not sent from my site
https://assure.ct.ws/
Versions:
WordPress: 6.7.1
WordPress MS: No
PHP: 8.2.25
WP Mail SMTP: 4.2.0
Params:
Mailer: mail
Constants: No
Server:
PHP.mail(): Yes
PHPMailer Debug:
Could not instantiate mail function.
Debug:
Email Source: WP Mail SMTP Mailer: Default (none) PHPMailer was able to connect to SMTP server but failed while trying to send an email.
emails sent from my site are not delivered. Kindly check through the error message posted about and assist.
Thank you.
php mail is (mostly) disabled on free hosting, click the link below as it contains a link to a guide for setting up smtp mail using gmail
I have set up an external SMTP on my domain but says Sender domain is not valid
I use [email protected] as sender domain…
How do i create a valid sender domain
see error message below:
Versions:
WordPress: 6.7.1
WordPress MS: No
PHP: 8.2.25
WP Mail SMTP: 4.2.0
Params:
Mailer: smtp
Constants: No
ErrorInfo: The following From address failed: assureng(at)gmail.com : MAIL FROM command failed,Sender domain is not valid. ,554,5.9.2SMTP server error: MAIL FROM command failed Detail: Sender domain is not valid. SMTP code: 554 Additional SMTP info: 5.9.2SMTP server error: MAIL FROM command failed Detail: Sender domain is not valid. SMTP code: 554 Additional SMTP info: 5.9.2
Host: smtp-pulse(dot)com
Port: 587
SMTPSecure:
tls
SMTPAutoTLS:
bool(true)
SMTPAuth:
bool(true)
Server:
OpenSSL: OpenSSL 1.1.1w 11 Sep 2023
Please check with sendpulse.
Most likely you will need a custom domain
Please note that most email providers will only let you send emails from domains and email addresses that they are authorized to send email for. For a Gmail address, that’s only Google.
I’m not familiar with SendPulse, but I expect that you will need to add your own domain name to their platform, and then send emails using addresses like [email protected].
Gmail especially is quite strictly tuned so sending email from a Gmail address from any other server will not work, because Gmail hasn’t authorized your mail server to send email on their behalf.
