Dser Connecting problem
Jozioceans.cf
Access to fetch at ‘https://jozioceans.cf/wp-json?time=1612319155036’ from origin ‘https://woo.dsers.com’ has been blocked by CORS policy: No ‘Access-Control-Allow-Origin’ header is present on the requested resource. If an opaque response serves your needs, set the request’s mode to ‘no-cors’ to fetch the resource with CORS disabled.
I tried to connect my woocomerse website to the dser website but it failed even after doing what I was told to do so they told me to go to my hosting website they will be able to fix it
I think that’s because security system. You can use CloudFlare to bypass it
Oh ok thanks but how do I do that?
How do I bypass it using cloudflare
