Domains blocked issues
Hello InfinityFree Support Team,
I am hosting my website on InfinityFree under the free subdomain [abuhasnat.wuaze.com] (please replace with your actual subdomain).
Recently, this domain has been blocked by most ISPs in Bangladesh. As a result, my visitors from Bangladesh cannot access my website without using a VPN. This is a big issue because I have shared and backlinked this URL in many places.
I kindly request your assistance with one of the following solutions:
1. Provide me with an alternative working subdomain (such as *.42web.io or others that are not blocked in Bangladesh).
2. Or, set up a redirect from my existing subdomain [abuhasnat.wuaze.com] to an alternative subdomain that works globally.
This will help me keep my backlinks and continue serving my visitors without disruption.
Thank you very much for your support.
Best regards,
[Abu Hasnat]
Hello, and Welcome to the InfinityFree Forum @Dev-Hasnat!
You can add a new Subdomain through the Client Area (make sure to select anything but wuaze.com), then move all files over to that new Subdomain
Redirect will not work.
The block is happening here, at the ISP level:
But a redirect is happening only when you reach the web server.
Because the ISP is blocking you from accessing the domain, there’s simple no way to make a redirection on something after ISP happens.
