Domain stuck with ezyro.com or profreehost
naumanhanif.com
I wanted to host my website using infinityfree with free plan but earlier it was hosted on profreehost now when I try to add my custom domain at infinityfree it say it is hosted with ezyro.com but actually i had closed my account there (i mean profreehost).
Hi, welcome to the community. Admin’s reseller authorities are limited to InfinityFree. You’ll have to contact ProFreeHost directly and ask them to remove your domain from your account there.
It should be noted though that both hosting companies backends are identical. May I ask why you’ve decided to switch to InfinityFree?
Please note that “closing” is not the same as deleting. It’s the state we call “deactivated”.
Basically, the account is locked in place and inaccessible. It means your website and control panel will be inaccessible, but any domains that were on the account when the account was closed will remain on the account until the account is deleted.
To fix this, you can reactivate the account, and when it is back up again, go into the control panel and delete your domain from the account.
When you remove a domain from an account, it instantly becomes available to add to another hosting account.
