The domain is not registered. Please register the domain before adding it to your account.
I’m trying to add the domain dreamground.or.kr to my account, but I keep getting the error above. Here is the result from the official KISA/KRNIC WHOIS (whois.kr) lookup:
The domain is properly registered and the nameserver information is correct. Since it was registered recently (September 21, 2026), I suspect InfinityFree’s verification system may not have picked it up yet. Could you please check on this?
InfinityFree Account ID: (your account ID here, e.g. if0_42977251)
This particular error seems to be caused by a registration check in the members area. It checks whether the domain name is actually registered before proceeding.
Since .or.kr domains support RDAP lookups (the modern replacement for WHOIS), the members area tries to look up the domain information via RDAP. However, the RDAP server for .or.kr does not have a valid SSL certificate, so the connection fails, and this gets translated to the domain not existing.
While the RDAP server of the registry malfunctioning is clearly an issue, so is how the members area responds to it. That’s a bug I will look into.
In the mean time, you can try adding the domain through the hosting control panel instead, which doesn’t use this check. You can find it in the Hosting dropdown in the side menu of your account.
