Hello, I bought a domain which ends “ .si”. Read what it says: How can i add .si? The “example” will be replaced with an actual name, don’t worry. thanks.
You have to add the specific domain name that you registered, not the entire extension.
thanks, i tried and it helped.
I created an “account” for the website where I entered my domain name and added “si” domain, will account be created today on infinity free? I bought the premium plan.
Type “si” instead of “.si” there.
This is a bug, I can see why you’d enter it with the preceding dot, but this form doesn’t expect that.
