Hello,
i got problem with linking domain from my provider to infinityfree, if i set nameservers to IF website works normally, but i got minecraft server on subdomain which doesnt work with nameservers pointed on IF, so i tried setting up the basic provider NS and adding IF NS so theyre all in there, but the website doesn’t work. So, how to get my web on my domain and minecraft server on my subdomain, what nameservers should i set up?
Thanks
You’ll want to change your nameservers back to what they were before, and create an A record to your site’s IP address. See the below article for more information.
Thanks! That worked, but my images and fonts doesn’t work, is there any fix for this? Thank you
There is probably a way to fix your fonts and images, yes.
But it’s probably not a DNS issue, and you have not given any more information to troubleshoot it than “doesn’t work”.
Could you share your website URL so we could have a look?
hey, yeah i think my issue is related to wordpress, so i will move to their support, but if you want to check its oakmpirate.000.pe and oakmmc.fun
Thank you, that helps a lot.
The main picture on the home page is working for me on the 000.pe website, but not on the .fun website.
This is because your website is still configured to use the 000.pe domain, so all URLs on the page include your 000.pe domain. And because our hosting blocks hotlinking, these URLs don’t work when they are used on your .fun domain.
To fix this, you could do the following:
- Choose which URL your website should be available at.
- Update your website configuration to use this URL.
- Redirect the other URL to your main website URL.
