Hello, I’m trying to connect my DomainKing domain to my InfinityFree account, but I can’t find the NS records for my account. My InfinityFree username is HIDDEN BY MOD (email = PII) . Can you please provide me with the NS records for my account? Thank you for your help.
Oxy
April 12, 2024, 7:45am
2
Hi and welcome to the forum
Before adding your domain name to your hosting account, you need to point it to the InfinityFree nameservers. This guide will walk you through the necessary steps using Spaceship as an example. Keep in mind that different domain registrars have different interfaces, so the exact steps may vary.
Step 0: Find the correct nameservers
Before changing your nameservers, you need to determine which nameservers to use. The appropriate nameservers depend on your account type:
For new accounts or exist…
If you want to host your own domain name with InfinityFree, the default way to verify your domain is to set the nameservers first. However, there are cases where setting the nameservers ahead of time is not desirable (for example if you have an existing site which cannot go down) or if your domain provider does not let you set our nameservers.
Fortunately, InfinityFree now has the ability to host your domain name with us without having to change your nameservers ahead of time! This guide explai…
