Hello so yesterday I set up a custom domain from google domains and put it on a parked domain in infinity free (progamermoment(dot)com). Then on wordpress I made the domain redirect progamermoment.com. I also set up an ssl certificate and a custom resource record to point my website to a www subdomain.
Today when I woke up I wanted to edit my website and when I searched it up i got this error message, DNS_PROBE_FINISHED_NXDOMAIN. It doesn’t have to do with wordpress because I tried the original domain (progamermoment(dot)epizy(dot)com) and it worked. I already tried everything, using these custom name servers:ns1byetorg ns2byetorg ns3byetorg ns4byetorg ns5byetorg (i did put them with dots in between i just deleted them here because I cant put more than 2 links on a post). I also tried to remove the www custom resource record. Nothing is working, how do I fix this?
yeah but that is the subdomain link, when you try to use the real domain(progamermoment.com) there is an error. Also I already have ssl on the real domain and I dont want to use a subdomain for my website.
I just checked your domain, and I see you have both Cloudflare and our nameservers on your domain.
As a rule of thumb: never mix different sets of nameservers.
If you want to add your domain to our hosting, your domain should only have our nameservers. If you want to add it to Cloudflare afterwards, you need to only use Cloudflare’s nameservers.
The domain is not reachable now because the Cloudflare nameservers don’t seem to contain any DNS records. So you’ll need to set those up (or switch back to our nameservers).
