DNS issues
At this stage, I have no intention of upgrading my plan, as I initially signed up for the free package purely for testing purposes. My original goal was to translate the e107 CMS into Estonian and use the hosting environment to test the translation and functionality before committing to the project long-term.
However, I find it disappointing that, despite 2–2.5 weeks having passed, you have still not managed to get my domain working properly. At present, the domain is only accessible by manually adjusting DNS settings, which is clearly not a proper or acceptable solution.
I would expect a basic domain configuration issue to be resolved within a reasonable timeframe, especially for a new customer who is simply trying to test your services. Until this issue is properly resolved, I see no reason to consider upgrading to a paid plan.
Which internet provider and country are you connecting from, and what do these two commands return? Replace the domain with your free infinityfree.io subdomain.
nslookup yourdomain
nslookup yourdomain 1.1.1.1
I’m guessing that “manually adjusting DNS settings” means switching your device or router to a public DNS server like Cloudflare’s. If so, your domain probably isn’t misconfigured on our side. A free subdomain needs no setup, and your account is active.
Some internet providers and networks filter domains through their own DNS servers and return “not found” for ones they block. This is most common with free subdomains. If your normal DNS server fails and 1.1.1.1 gives an IP address, that is probably what’s happening. It would also explain why waiting hasn’t changed anything. The article says a domain that fails after 72 hours has a different cause than propagation.
This article explains how to tell the two cases apart:
It also says we can’t see these blocks from our side. Reports with the provider, country and nslookup output are how we find out where they happen.
If both commands return the same IP address, tell me what your browser shows and I’ll look again.
I’ve moved your post to it’s own thread so we can help you individually.
Posting on other people’s threads only confuses things.
It would also be helpful if you could provide the domain you’re having problems with as only admin is a member of staff, the rest of us are volunteers who can’t see your account
From what you’ve described it sounds like the problem is a block on your side not a housing level problem.
This strongly supports that there issue is not a hosting issue.
Have you considered trying a custom domain such as a free .pp.ua domain to see if your ISP are simply blocking the domain your usern.
The other thing to be aware of is the premium plans are provided by IFastNet not InfinityFree.
