Savvas
July 17, 2024, 10:30pm
1
I need help here is sample code
<?php
// Initialize cURL session
$ch = curl_init();
// Set cURL options
$url = 'https://aviationweather.gov/api/data/metar?ids=KMCI';
curl_setopt($ch, CURLOPT_URL, $url);
curl_setopt($ch, CURLOPT_RETURNTRANSFER, true);
curl_setopt($ch, CURLOPT_HTTPHEADER, [
'Accept: */*'
// Execute cURL session and capture the response
$response = curl_exec($ch);
// Check for errors
if(curl_errno($ch)) {
echo 'Error:' . curl_error($ch);
// Close cURL session
curl_close($ch);
// Output the response
echo $response;
Once I run it on the website, I get the error: ‘Could not resolve host: aviationweather.gov ’. But if I run the same code on localhost, I successfully obtain the data. I suspect it’s a DNS issue. How can I fix it?
This is mostly a server issue that is not something you can fix. Admin has to report this to the actual server operators to get this fixed, so you probably have to wait.
Most likely that API endpoint is blocked by the server, but Admin will be able to take a closer look and raise a question upstream if needed.
I’m having the same issue with catalog.archives.gov . How do I get InfinityFree to investigate?
Admin
July 19, 2024, 9:27am
5
I’m sorry for the delay.
I have checked the issue and there indeed seems to be a DNS problem on the free hosting servers preventing connections to these .gov domains.
I have asked iFastNet to investigate the issue.
Admin
July 19, 2024, 9:44am
6
I’m sorry again for the delay. The issue should now be fixed!
Yes! Thank you very much!
system
Closed
July 26, 2024, 12:20pm
8
