Both domains are now listed directly under Domains in my hosting account. My hosting dashboard shows a numerical Website IP, and the main domain has an A record, but the “pro” subdomain has no A record on Google Dig or DNSChecker. My browser shows “DNS_PROBE_FINISHED_NXDOMAIN”.
My WordPress files are still visible in File Manager. Could you please check whether the subdomain is correctly registered in your DNS system and help restore access without losing my website files?
The article below covers DNS_PROBE_FINISHED_NXDOMAIN. It says that if a free subdomain is listed in your account, there’s nothing for you to set up. Free subdomains are normally given up to 72 hours to start working everywhere after a change. If one still doesn’t work after that, it’s a case for a support topic.
So the first thing I need to know is when you recreated whoamikids.great-site.net and added pro again. Was it more than 72 hours ago?
If it was, please post the output of these two commands for pro.whoamikids.great-site.net, plus your internet provider and country:
I agree with what @dan3008 said. This is probably a bug on our end. However, sub-subdomains are no longer supported, and so I don’t think that fixing the issue will have any priority.
I think your best bet is to remove the domain from the account and add it again. That will reconfigure everything, including setting up the required DNS records.
