Dns caching issues
https://bluecrest.kesug.com
My website is unreachable in most countries due to DNS caching, please can this issue be fixed
Can this be fixed
Which countries can’t reach the site, and what do visitors there actually see? An error page, a timeout, or a “site can’t be reached” message? The exact text would help, because “DNS caching” is a guess at the cause and the same symptom can come from other things.
Your hosting account was only created a couple of days ago. If DNS caching is the cause, it fits what this article describes. Resolvers (usually run by an internet provider) keep old DNS results for different lengths of time, and some can serve outdated records for weeks. Those caches expire on their own, and the article says this isn’t something website owners or hosting providers can fix:
I can’t tell yet whether that’s what is happening to you. A quick check would help. On an affected connection, switch the device’s DNS resolver to Google Public DNS, or try the site from a different network such as mobile data. If it loads, the problem is the old resolver’s cache. If it still fails, it’s something else, and the exact error text will show what.
Welcome to the forum
How do you know this is the problem? and is your site less than 72 hours old?
if its less than 72 hours, you just have to wait. If its older, the problem is unlikely DNS caching.
That’s not what I see. I see all green checks on dnschecker.org, so your domain is resolving globally.
As for “fixing” DNS caching, the answer is no. The DNS cache is on your computer, your network, your ISP or your configured DNS resolvers. We do not have control over any of them.
Delays due to DNS caching is just how the internet works. We cannot change that.
