(https://dailyupdates.lovestoblog.com)
(incorrect user name and password)
Hey there, Your question isn’t clear. Could you please address the issue you are having?
i have issue to login cpanel because I have forgot my username and password, similarly I cannot login to wp-admin panel
please suggest any way how can I fix this
Please follow the below article.
You can view your control panel password at any time through the client area. If you changed the password through the control panel directly (using the change or reset password functionality), that password may not be correct. If so, you can reset it on the Account Settings page in the client area.
As for your WordPress admin password, we don’t have that one. If you installed WordPress with Softaculous, you can use Softaculous to login to WordPress, and also see and/or edit the login details.
Alternatively, you can reset your WordPress password through phpMyAdmin: Reset Your Password – Documentation – WordPress.org
